March 23, 2022 at 2:17 pm
Susan
SubscriberMarch 24, 2022 at 3:15 amKeyur Kanade
Ansys EmployeeAs Ansys Staff, we can not download attachments. Please upload images using upload image functionality.
The min orthogonal quality should be above 0.1 to proceed to solver. If it is less than 0.1 then please improve the mesh.
First check the locations of the bad elements. Please see following video for the same.
https://www.youtube.com/watch?v=ZDADSSN8hOs
Once you have locations, please check if you can improve mesh using different mesh sizing. Please see following video.
https://www.youtube.com/watch?v=w4q6q8nKF3U
If this does not help, you may need to check if you can use pinch control or virtual topology.
https://www.youtube.com/watch?v=wdKMqfJV1Ys
https://www.youtube.com/watch?v=RELLrEJ9chg
If this does not help, please go to geometry and modify or simplify geometry at those locations in SpaceClaim.
Regards Keyur
March 24, 2022 at 4:25 pmSusan
SubscriberHi, Thank you so much for your help. I have solved that and it's converged
However, I got the wrong Cd value when AOA=-12┬░, my result is around -0.23.
March 24, 2022 at 4:40 pmRob
Ansys EmployeeAs the coefficients are linked to the reference values I'd start there.
March 24, 2022 at 4:56 pmMarch 24, 2022 at 5:01 pmRob
Ansys EmployeeThe drag or the reference values? Please follow the various tutorials that cover NACA aerofoils of various types.
March 24, 2022 at 5:16 pmSusan
SubscriberI don' think the drag coefficient is correct. It is different from NASA experiment.
But I set the reference values as https://su2code.github.io/tutorials/Inc_Turbulent_NACA0012/.
Should I change reference values when calculate Cd? But the value of lift coefficient Cl is correct.
March 25, 2022 at 11:28 amRob
Ansys EmployeeIf lift is correct also check mesh resolution both on the wing but also in the wake region. Without opening the link it's hard to comment, how does the set up compare to the video/example in Fluent's Help?
March 29, 2022 at 1:39 pmSusan
SubscriberThanks, Rob, will do.
Viewing 8 reply threads- You must be logged in to reply to this topic.
Trending discussions- Floating point exception in Fluent
7584
4430
2949
1422
1322
