February 28, 2022 at 11:50 am
crf202589
SubscriberHi , I am Rupesh kumar, M.tech student ,IIT Delhi. While doing my Thesis work to simulate the structure on CHARGE module , after turning on the MATLAB integration tool I am getting , "Failed to post close command error 1717" & "Unable to tear down the job tree". All the structure running well before ,now not getting this error . kindly help.
February 28, 2022 at 6:50 pmLito Yap
Ansys EmployeeTry to run using "Local Computer" as your Job launching preset. See this post for details.
- Error on Lumerical device
2524
2066
1279
1096
457
