Discovery Import
Discovery Import
Close more than 1 tab
    • mf
      Hi guys. I can see this have been posted before, but there is no replies.
      1) I have a Customer that is requesting the same thing. Is there any news around this? (Being able to close more than 1 tab without closing SpaceClaim intirely.)
      2) And also, is it possible to open a design without the drawing sheet opening aswell?
      He refers to an old case from 2014 at support@spaceclaim.com named: #CASE12562 - "SC is slow". Which he didnt get a reply to aswell.
    • Charudatta Bandgar
      Hello MF
      Regarding the idea suggested let me check I will get back to you.
       I will get back to you on this as well.
      Regards.
      Hello MF
      The file will open in the same state as it was last saved. So if you close all the drawing sheets and save the file, the next time you open it no drawing sheets will open. Please try this on your end, and let me know if it works for you.
      Regards.
      • mf
        Charudatta Bandgar Thanks for the reply. This works.
        Looking forward to see what they say about the "Close more than 1 tab".
        In the buttom right corner there is 2 arrows and an x. would be lovly to see an added button or the x changed into "Close all".
