May 16, 2022 at 8:09 am
Bart
SubscriberHi, all,
I have a problem relating to closed_homogeneous reactor in chemkin. At first, the closed_homogeneous reactor calculation can run well, however, this reactor simulation cannot work now. The message shown as ' ...closed_homogeneous is running...' is existing, but never results for a long time.
And, other modules such as laminar speed calculation can run well. I used ansys 2021 in win11. It is strange, I have no idea about this.
Best regards,
Bart
May 19, 2022 at 3:36 pmRK
Ansys EmployeeHello Bart,
If it runs for a while and then just stops, it has probably failed, in which case you can look at the Chemkin.out file in the working folder to see why.
May 20, 2022 at 6:32 pmBart
SubscriberRK Sorry that I haven't described the problem clearly. The chemkin (ansys 2022) could run well using closed_homogeneous reactor some days ago. However, this reactor couldnot run well these days using the same condictions. The message shown in the consoles is "Start running Closed_Homogeneous (C1)......", but never without any result. Then I just tried to install chemkin in ansys 18.0, and the reactor could run well.
I have no ideas about this problem.
Best regards Bart
May 25, 2022 at 3:06 pmRK
Ansys EmployeeHi Bart,
Did you take a look at the .out file?
May 25, 2022 at 3:58 pmViewing 4 reply threads- You must be logged in to reply to this topic.
3930
2649
1863
1272
610
