cmp flow field analysis
    • hone zifu
      May I ask which step of my flow field analysis is wrong, I want to know the flow field situation at each time point
      I suppose the first question is: what do you expect to see? Second one is why do you have overlapping cell zones?
    • hone zifu
      This is the model I refer to. The polishing fluid flows from the top to the bottom of the pad. The pad rotates and the wafer rotates for friction. I currently have the direction of the polishing fluid flow. Others are wrong when running calculations. I don’t know which link is wrong.
      How did you set up the pad motion?
    • hone zifu
      I set the pad rotation and wafer rotation in this way, and I only mesh the liquid flow area between the two parts of the model
    • hone zifu
      My space model of liquid flow
      For the model, I set VOF and standard k-e
      For other conditions, I set the inlet flow rate and the outlet flow and the rotation of the wafer and pad surface
      Initialize with default value
      Have a look at sliding mesh or reference frames depending on whether the pad moves relative to the inlet. Does the slurry fill the whole fluid domain?
    • hone zifu
      I didn't refer to the sliding grid, because I didn't take into account that the rotation is a plane, not geometry, and the liquid part will not flow to the entire area.
      If you have no rotation why do the vectors in the original image go around the domain, and why does the second figure have arrows implying rotation?
    • hone zifu
      I only have to rotate the face, but I have not set a moving mesh
      OK.
      If you ran transient did you save data or take an image at each (or regular interval) timestep?
    • hone zifu
      Because now I'm not sure if my flow field setting is correct, so I haven't done that yet
    • hone zifu
      Where do I need to modify the boundary conditions?
      As I can't see exactly what the motion is supposed to be it's difficult to comment.
Viewing 13 reply threads
