Code Write
    • Hasan İlker ÇELİKER
      Can I ask you something?
      How do we calculate the values on the side of the codes in the example I gave?
      *SET,_FNCNAME,'HEATFLX'
       *DIM,_FNC_C1,,1
       *DIM,_FNC_C2,,1
       *DIM,_FNC_C3,,1
       *DIM,_FNC_C4,,1
       *DIM,_FNC_C5,,1
       *DIM,_FNC_C6,,1
       *SET,_FNC_C1(1),8625279.2 ! A = Beam power density (pW/um2)
      *SET,_FNC_C2(1),-2 ! B = -2 for Gaussian, -3 for Goldak
      *SET,_FNC_C3(1),0.0 ! C = X offset
      *SET,_FNC_C4(1),-10.0 ! D = Y velocity
      *SET,_FNC_C5(1),15 ! E = Y offset
      *SET,_FNC_C6(1),1.5 ! F = Beam radius
      *SET,_FNCCSYS,12  *DIM,%_FNCNAME%,TABLE,8,16,1,,,,%_FNCCSYS%
       ! ! Begin of equation: A*exp(B*(({X}-C)^2+({Y}-D*{TIME}-E)^2)/F^2)
      *SET,%_FNCNAME%(0,0,1), 0.0, -999
      *SET,%_FNCNAME%(2,0,1), 0.0
      *SET,%_FNCNAME%(3,0,1), %_FNC_C1(1)%
      *SET,%_FNCNAME%(4,0,1), %_FNC_C2(1)%
      *SET,%_FNCNAME%(5,0,1), %_FNC_C3(1)%
      *SET,%_FNCNAME%(6,0,1), %_FNC_C4(1)%
      *SET,%_FNCNAME%(7,0,1), %_FNC_C5(1)%
      *SET,%_FNCNAME%(8,0,1), %_FNC_C6(1)%
      *SET,%_FNCNAME%(0,1,1), 1.0, -1, 0, 1, 2, 2, 19 <-- how to find this data??
      *SET,%_FNCNAME%(0,2,1), 0.0, -2, 0, 2, 0, 0, -1
      *SET,%_FNCNAME%(0,3,1), 0, -3, 0, 1, -1, 17, -2
      *SET,%_FNCNAME%(0,4,1), 0.0, -1, 0, 1, 20, 3, 1
      *SET,%_FNCNAME%(0,5,1), 0.0, -2, 0, 1, 3, 2, -1
      *SET,%_FNCNAME%(0,6,1), 0.0, -1, 0, 1, -2, 2, 21
      *SET,%_FNCNAME%(0,7,1), 0.0, -2, 0, 2, 0, 0, -1
      *SET,%_FNCNAME%(0,8,1), 0.0, -4, 0, 1, -1, 17, -2
      *SET,%_FNCNAME%(0,9,1), 0.0, -1, 0, 1, -3, 1, -4
      *SET,%_FNCNAME%(0,10,1), 0.0, -2, 0, 1, 18, 3, -1
      *SET,%_FNCNAME%(0,11,1), 0.0, -1, 0, 2, 0, 0, 22
      *SET,%_FNCNAME%(0,12,1), 0.0, -3, 0, 1, 22, 17, -1
      *SET,%_FNCNAME%(0,13,1), 0.0, -1, 0, 1, -2, 4, -3
      *SET,%_FNCNAME%(0,14,1), 0.0, -1, 7, 1, -1, 0, 0
      *SET,%_FNCNAME%(0,15,1), 0.0, -2, 0, 1, 17, 3, -1
      *SET,%_FNCNAME%(0,16,1), 0.0, 99, 0, 1, -2, 0, 0
      ! End of equation: A*exp(B*(({X}-C)^2+({Y}-D*{TIME}-E)^2)/F^2)
    • Mike Rife
      Hi Hasan
      The format of tables from the Mechanical APDL function tool is not documented.  Mike
      The values in this table are handwritten values. That's why I'm asking.
      https://www.youtube.com/watch?v=HsohSHa0L6s&t=94s this video
      How were these values written?
      My goal is to obtain a temperature distribution as in the relevant video, and then to obtain material depth. I want to remove paint from the surface.
    • Mike Rife
      Hi Hasan
      No, the values in the table were not hand written.  The video creator used Mechanical APDL interactively to create the equation and evaluate it over a time range.  Then exported it out - the exported APDL text version was then copy/pasted to the WB Mechanical Commands Object.  They just did not show those steps.
      See for example this Forum discussion:
      https://forum.ansys.com/forums/topic/mathematical-function-in-ansys-apdl/
      mike
Viewing 4 reply threads
