Coefficient of pressure problem
    • ghs007
      I'm modeling the wind load on a house caused by high velocity wind 30 m/s +. I'm trying to get the coefficient of pressure on the roof but the values are in th range of 2 to -6. That range isn't correct as it doesn't match with experimental data. What can I possibly be doing wrong.
      I already set the reference velocity/pressure value to the value at the inlet.
    • RK
      Please make sure your setup is right - correct BC and solver settings
      Make sure the solution has converged.
      You can setup a report definition at region of interest to check if the solution has converged.
    • DrAmine
      More details about BC and depth of convergence are helpful to assist you.
