August 26, 2019 at 1:52 pm
Mn65
SubscriberI intend to establish a predictive model for adhesively single lap joint under static loading using cohesive zone model. I need to add codes or program for calculating the mechanical properties of adhesive under moisture and temperature. How can I do that?
Are there any options to investigate the mechanical behavior of bonded joints under loading, temperature, and moisture simultaneously?
Thanks in advance for your help.
August 26, 2019 at 8:04 pm
Wenlong
Ansys EmployeeHi Mn65,
User-programmable features would be somewhere you can investigate:
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v194/ans_adv/Hlp_G_ADV7_1.html
Bests,
Wenlong
August 26, 2019 at 8:11 pm
Mn65
SubscriberHi Wenlong,
Thank you for your response.
I have logged in as a student and I don't have access to the link you sent me. Is there any way to have access to this link?
Marzieh
August 26, 2019 at 8:20 pm
Wenlong
Please refer to the following post:
https://forum.ansys.com/forums/topic/how-to-access-the-ansys-online-help/
Wenlong
August 26, 2019 at 8:27 pm
Mn65
SubscriberThank you very much
2066
1279
1096
457
