June 23, 2021 at 9:41 am
Raghu79
SubscriberHi everyone, I'm working on a project to simulate adhesive bonding failure and studied that CZM is a suitable method to obtain the maximum load for debonding failure. I have input the necessary parameters but I can't seem to achieve the failure load of the model. Does anyone know what can be done to observe the failure? Will I be able to achieve it just by manipulating the parameters or is there something I need to input/add. My end-goal is to plot the load vs displacement curve with failure. Thanks in advance. Attached are some images of my project. Your help and guidance is very much appreciated.
June 23, 2021 at 12:18 pm1shan
Ansys EmployeeThe load displacement curve looks alright - elastic loading till a peak point followed by softening. What do you mean by "cant observe failure"? Also your maximum tangential contact stress is 1E-30 Pa, which doesn't look realistic. This could be the problem.
Regards Ishan.
June 23, 2021 at 3:25 pmRaghu79
Thanks for your prompt reply. My apologies, I will change the contact stress.
What I meant by the failure is to observe a "fracture" when the adhesive bond fails. I have attached an image for your reference and would like to achieve the similar curve. Am I able to achieve this kind of curve? Your suggestion is very much appreciated. Thank you.
Raghu.
March 9, 2022 at 11:06 pmKaci
SubscriberHey
Can I contact you please? I really need you as fast as possible pleaaase.
Best regards
November 16, 2022 at 5:09 pmvangapandu goutham
Subscriberhey Raghu!
the work that you have shown here plays a key part in my project
could you please let me know how you have achieved the load vs displacement curve
1) how did you model your adhesive
2) why can't I see any deflection in my curve, it was going straight up!!
can you share me few insights, as you have gone through this,
Thank you in Advance
Viewing 4 reply threads- You must be logged in to reply to this topic.
2630
2110
1335
1110
461
