March 3, 2022 at 3:31 pm
windowtears
SubscriberHello, i am tying to find inductance of my coil design which wrapped to ferrite core with relative permeability of 3000. My question is i am expecting X3000 times bigger inductance compared to air gap design due to simple coil inductance formula. But this kind of a core only multiplies the inductance like 10-50 times which doesn't hold with the formula. Do you have any idea about what is the reason of this fault?
I'm using magneto static solution and my solutions without using a core holds with the formula so i am thinking there is a mistake about the core implementation.
Kind regards...
March 9, 2022 at 11:04 amNavya C
Ansys EmployeeHi @windowtears The permeability of the core changes nonlinearly and after a certain point, it gets saturated so you will not see a linear change in the inductance with an increase in turns or an increase in current.
Please check the material properties you used for the core.
Regards Navya
- Maxwell, HFSS or Q3D?
- Error
2656
2120
1347
1118
461
