June 16, 2019 at 11:06 pm
May 19, 2020 at 3:07 am
zoeartesyn
SubscriberI think both two functions you mentioned had the same current conducting path. But you can by section the rotor bar in the position you want, and create a surface, then assign coil terminal.
May 19, 2020 at 3:09 am
zoeartesyn
SubscriberIt's worth mentioned that coil terminal must be added at the edge of a region. I don't think your way had a closed circuit.
May 20, 2020 at 12:20 pm
Viewing 3 reply threads
- The topic ‘Coil Terminal’ is closed to new replies.
Trending discussions
- How does Ansys Twin Builder implement different simulation steps for subcircuits
- Ansys-MATLAB Co-Simulation
- Compute near field simulation with current
- Ansys Resonance simulatioin error
- Double-sided LIM external circuit error
- Calculating E-field tangential to a 2D resonant structure on a sapphire chip
Top Contributors
2778
965
841
599
591
Top Rated Tags
© 2025 Copyright ANSYS, Inc. All rights reserved.
