April 29, 2023 at 5:44 am
Plebian Seth Tamba
SubscriberDoes anyone know how can I simulate a cold joint in a reiforced concrete model? What contact should I use?
May 2, 2023 at 12:20 pm
John Doyle
Ansys EmployeeI am assuming by "cold joint" you mean the interface between two bodies of concrete that have different material properties caused by poring and curing at different times?
If so, I would recommend a conventional bonded contact pair that is associate with a Cohesive Zone Material (CZM) model, so that the bond at this interface has a limit in tension and shear.
May 2, 2023 at 1:23 pm
Plebian Seth Tamba
SubscriberThank you for your answer. Is it automatically applied to the interface when a CZM model is applied to the material? Does both concrete material in contact should have a CZM model?
- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
5282
3299
2469
