Cold Plate Boundary Condition
    • Umair Syed
      I am designing a cold plate but I want to input conditional volume flow rate dependent on cold surface temprature. For example if the temp increases to 350K i want the mass flow rate to be 0.0446 kg/s if it is lower than 350 I want to turn off the flow rate to 0. I cant write a UDF can this be achieved using expression editor? If so how?
    • SRP
      You can create expression by creating a condition using 'if' condition.
      For more details, please refer to fluent user's guide: 5.3. Creating and Using Expressions (ansys.com)
      If you are not able to access the link, please refer to this forum discussion: https://forum.ansys.com/forums/topic/using-help-with-links/#latest
      Thank you.
