STEM
STEM
Color code of electric wires
    • Keyur Kanade
      What does the color coding of the household electric wires indicate?
    • Karthik R
      Administrator
      Following a standard color coding will help in classifying the function of each wire and also helps in maintaining the safety standards.
       In the United States, household color coding is as follows,
       3-phase line (L1)/ single phase Line - Black
       3-phase line (L2) - Red
       3-phase line (L3) - Blue
       Neutral (N) - white
       Earth/Ground (G) - Green/Green-Yellow, Bare wire.
    • Keyur Kanade
      Thank you, @Kremella ! Is it same all across the world?
    • Karthik R
      Administrator
      No, different countries use different color codings for identification.
       For example in Europe it is as follows,
       3-phase line (L1)/ single phase line - Brown
       3-phase line (L2) - Black
       3-phase line (L3) -Grey
       Neutral (N) - Blue
       Earth/Ground (G) - Green-Yellow
    • Keyur Kanade
      Hello @Kremella , What about India?
    • Karthik R
      Administrator
       In India, it is identified as follows,
       3-phase line (L1)/ single phase line - Red
       3-phase line (L2) - Yellow
       Neutral (N) - Black
Viewing 5 reply threads
