Discovery Import
Discovery Import
Color of the locked elements
    • cbur
      When you lock an element, its color changes. However in the appearance properties the color code remains the same...
      Is it possible to prevent the change of color when locking an element?
      Regards
    • Naresh Patre
      Hello charlie
      When a body is locked, it gets faded in the graphics window, but that doesn't change its color in the Properties panel. The fading helps to quickly identify the locked objects in the model. So this is intended behavior.
