April 20, 2022 at 6:55 am
arindam.rs.iiests
SubscriberMy models contain element-by-element density and Young's modulus which I input through command. I want to colour plot the material variation in Workbench but am unable to achieve that. How can I do that ?? Thanks in advance.
P.S. I am using ANSYS 2019R2.
April 20, 2022 at 12:23 pmAkshay Maniyar
Have you tried to use material plot option? Please check the Ansys help link, for more details.
Thanks Amaniyar
April 21, 2022 at 7:50 amarindam.rs.iiests
SubscriberThank you for your response.
I did give the material plot option a try with no results.
I am adding a 'Commands' object under 'Static Structural' which, I learnt, replaces the previously assigned isotropic material with the commands before solving. I added the 'Commands' object under the 'geometry' too which also did not generate the required material plot.
Is there any other way to plot the material??
April 25, 2022 at 11:28 amAkshay Maniyar
Can you share the image of command snippet which you are using?
Thanks Amaniyar
April 29, 2022 at 7:03 amViewing 4 reply threads- The topic ‘Colour plot of material property in Workbench’ is closed to new replies.
Trending discussions- Floating point exception
- How to indetify baffles in Fluent meshing
- How to delete elements on Ansys Workbench
- Meshing cylindrical bodies with holes
- Quality failure limits are exceeded on some solid bodies… in ansys meshing
- Problems in the meshing of my geometry
- Ansys Mechanical – Python Scripting – Access and input parameter
- Mesh Element Quality Display Style Not Showing
- Fluent Meshing Batch Mode – Problems workflow commands
- Local mesh refinement with targeted edge lengths at specified areas
8808
4658
3153
1680
1470
