Combin 39 use
    • adityaparpe
      I am aware of the fact that we can create a spring element manually in connection option. Is there any way of creating or defining a spring element or multiple spring elements by using APDL commands? If it is so, please help.
      Actually, I am working on bar-slip modelling in beam model and at the interface between concrete element and rebar element, there will be spring element which will connect them.
Viewing 0 reply threads
