Combination of moving mesh and dynamic mesh
    • Lee
              I encountered a problem when I used the UDF “DEFINE_CG_MOTION” and “DEFINE_ZONE_MOTION”, the warning message below popped up during simulation: Warning: incompatible interaction between moving mesh and dynamic mesh model.
      Model and settings description:
      (1) As shown in Figure 1, the whole model consists of 3 fluid zone: fluid_1, fluid_2 and fluid_3, each zone is connected with interface. Fluid_2, fluid_3 and wall_bot_f1 are moving with a velocity v, now, I use “DEFINE_CG_MOTION” to control the motion of moving face, and “DEFINE_ZONE_MOTION” for fluid_2 and fluid_3.
      (2) Interface settings: Interface_1: wall_bot_f1 and wall_top_f2;
      Interface_2: wall_bot_f2 and wall_top_f3;
      (3) Dynamic mesh settings:
      Deforming: wall_f1
      Rigid body: wall bot_f1;
      Rigid body: Interface_1;
      Rigid body: Interface_1-non-overlapping;
      Although the simulation can run normally, I am curious about this problem, what makes this happen? Does this problem influence the simulation result? How to solve it?
      I need your help and advice, thanks.
    • Federico Alzamora Previtali
      Can you provide more context as to why you are using CG_Motion for one and ZONE_Motion for the others?
      • Lee
        Hi, Federico,
                There are two reasons:
        1.If I use CG_MOTION for fluid_2 and fluid_3, too much surfaces I must set as rigid body in dynamic mesh, as shown in Figure 2;
        2."Warning: multiple subdivision required on zone 23. Subdivide using Constant Ratio"
        and "negative volume" error will pop up, as shown in Figure 3.
        Figure 2
        Figure 3
