July 11, 2023 at 7:47 am
Fraser Shields
SubscriberHi, I would like to combine multiple intersecting midsurfaces to create a model where each surface is bonded at their intersection. I am having issue with surfaces splitting when performing FEA. I have already attempted combining, welding and stitching to no avail. Any help would be much appresciated.
July 12, 2023 at 7:35 am
Aniket
Ansys EmployeeHave you tried the shared topology? -Aniket How to access Ansys help links Guidelines for Posting on Ansys Learning Forum
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7690
4484
2957
1435
1322
