September 18, 2022 at 12:59 pm
isacco83
SubscriberHi,
i have to to mesh a hollow cylinder geometry ONLY with hexahedrons, i'm struggling in combining two transition zones (ratio 1:3) one perpendicular to the other, as in the small cube that connect the two outer transition layers intersecting, i cannot find a way to get only hexahedrons (see attached picture)
September 18, 2022 at 2:23 pm
SubscriberHow many elements are through the pipe wall thickness?
September 18, 2022 at 3:30 pm
isacco83
SubscriberHi peter
in the fine areas i do 0,35 mm elements with edge division, the wall is about 3 mm thick, so i do 9 divisions, the transition zones are 0,7 mm large
September 18, 2022 at 5:04 pm
SubscriberWhat is the ID and OD of the pipe? I will need some geometry to try it myself.
What version of ANSYS are you using?
September 18, 2022 at 5:39 pm
isacco83
SubscriberHi Peter
thanks for the help, tomorrow i'll provide you the info, i don't have the proj. with me right now
September 18, 2022 at 5:50 pm
SubscriberNo problem, what verion of ANSYS do you use?
September 18, 2022 at 5:54 pm
isacco83
Subscriberthe latest 22 R2... but i'm not 100% sure, i have to check
September 18, 2022 at 10:11 pm
2146
1357
1148
462
