Combustion-CHEMKIN
    • Naiara
      I started with combustion in FLUENT and I did several tutorials. In all of them, in Species model, it is imported a CHEMKIN Mechanism.
      I would like to start doing my combustion simulation, but I do not know what to do with CHEMKIN Mechanism, that is, where it comes from? Can I generated a chemkin file considering my combustion gas?
      Finally, how does CHEMKIN works?
      My combustion fuel is natural gas.
      Thank you!
      Naiara.
    • Raef.Kobeissi
      there is a set library for certain species that you can use directly. What is the chemical formula of the natural gas you’re using?
    • Weiqiang Liu
      Hi Kobeissi,
      I am doing a simulation with methane gas phase and surface mechanisms. however,  I meet error like' received a fatal signal (segmentation fault)' at beginning of calculation. All the mechanism files and thermodynamic data can be imported into Fluent without any mistakes.
      I don't have UDF in my model. Do you know why? have you ever met this error before?
    • Naiara
      Hi!
      I am working with Natural gas, and I found GRI Mech 3.0 for methane combustion, is it another one with less soecies and reactions but still quite accurate?
      Thank you!
Viewing 3 reply threads
