COMBUSTION GAS TURBINE MODEL
    • Tạ Huy
      Hello researchers and FLUENT users. I have read and research an article: 5 Best Practices For Gas Turbine Combustion Meshing Using Ansys Fluent WP. In which the mosaic grid model is introduced for dividing the combustion chamber gas turbine. I have seen many paper and web that use this model. Please provide me the 3D model of gas turbine so that I can access it. I great appreciate your sharing. Thanks for your help.
    • Essence
      I am not permitted to share the model of the gas turbine from administrative point of view. If you are eligible for the technical support, please raise the Service Request on the Ansys customer portal and an engineer will approach you for the issue.
