August 2, 2019 at 7:44 pm
ozankekul
SubscriberHello My Friends,
i'm modeling combustion for 10 kw heat power and before simulating combustion , i calculate fuel requirement and correspondingly air ratio by hand. I would like to see that 10 kw heat power has been generated after simulating. How can i check this value in fluent after solution is converged. this would be very helpful. I will be waiting for your feedback.
Thanks. -
August 5, 2019 at 10:02 am
Ansys EmployeeHave a look at the flux reports: you may also need some more localised reporting & post processing to confirm heat loads.
2706
2142
1355
1144
462
