Command-Line system coupling. Fluent initial conditions from .dat file.
    • carmorper
      I'm trying to run a coupled analysis (transient thermal - fluent) by using the command line method, I followed the example from the help:
      DatamodelRoot().CouplingParticipant.ExecutionControl.InitialInput = 'mapdl.dat'
      DatamodelRoot().CouplingParticipant.ExecutionControl.WorkingDirectory = 'Struct'
      DatamodelRoot().CouplingParticipant.ExecutionControl.InitialInput = 'fluidFlow.cas'
      DatamodelRoot().CouplingParticipant.ExecutionControl.WorkingDirectory = 'Fluid'
      Everything works OK, but I would like to load a fluent .dat file at the beginning of the analysis in order to have initial conditions taken from a previous solved problem, I can't find out how.
      Thank you for your attention.
    • maryam
      I saw your post here i am going to run my fsi simulation (Transient structural and fluent) in HPC cluster but i am beginner at it. If you do not mind can you give me some informations how i can do this? or if it is possible send me the job files for running system coupling?
      Best,
      Mari
