April 13, 2022 at 1:56 pm
Vincent92
SubscriberHi,
I search how to generate a file contains data (structure and data name) linked to Inputs of Node and know the data connected on the output of Node.
FOr the moment i performe an analizys on generated code to extract this information. Do you have a command (or procedure ) or tools to perform this export?
April 14, 2022 at 3:01 pmRK
Ansys EmployeeHello,
May I know which Ansys software you are using?
April 14, 2022 at 3:09 pmViewing 2 reply threads- You must be logged in to reply to this topic.
Trending discussions- What are the OpenGL drivers supported by SCADE Display KCG?
- How to get event from Arinc
- What are the target supported to integrate SCADE Suite generated code?
- What are the OS supported by SCADE products for installation?
- Command or tool to extract information about input and output data associated to a specific node
- How does Medini calculate FITs based on mission profile?
- SCADE – FMU file
- Integrating C Code generated by KCG in Software Application
- ANSYS SCADE: The map iterator explained
- What is the most efficient way of implementing a FOR LOOP in SCADE Suite
7742
4502
2963
1449
1322
