Common walled fluid channel- modelling the flow
    • PradnyaG20
      I am developing a 2 d fluid channel network which has an inlet leading to different chambers which are common walled. The sketch isn't getting converted to a surface due to the open profile. Basically I wish to study the fluid flow by developing the sketch with all common edges of the chambers as walls. However I cannot mesh the domain because Design Modeler detects the sketch as an open profile and hence doesn't build the surface for meshing. How can I resolve this issue and proceed with my flow analysis?
Viewing 0 reply threads
