October 4, 2017 at 12:20 pm
Vishal Ganore
Ansys EmployeeYou can use a Solution Combination to find the difference between the two models. First, right click on the Model Object in the Outline Tree and insert a Solution Combination Object into the Outline Tree. In the Solution Combination worksheet window, right click on the header grid and add a row. In the created row, specify a coefficient of 1.0, the applicable environment, and the solution time point. Repeat the above procedure for the result set with the different set of boundary conditions, but specify a coefficient of -1.0. These steps will create a result set that is the difference between the environments. After defining the Solution Combination, RMB on the Solution Combination Object in the Outline Tree and insert the desired post-processing action (i.e., plot directional deformation). Then RMB and solve the Solution Combination.
October 4, 2017 at 2:39 pm
pgl
Ansys EmployeeHow can you compare simulation results for the same model with different boundary conditions?
April 12, 2018 at 4:07 am
maurya
Subscriberhello sir
i have doubt that when i have solved two problem in different file.
for ex. 1) cantilever beam with point load 10 N
2) cantilever beam with moment 10Nm
then where to use the solution combination in one or both.
can you show some video i tried to use for above case but not succeeded.
thankyou
October 5, 2018 at 1:03 pm
Ashish Khemka
Ansys EmployeeMaurya, you should have the models linked to each other for Solution Combination.
Ashish Khemka
February 6, 2019 at 12:53 pm
shivajideshmukh
SubscriberIs solution combination valid for different load cases with different boundary boundary condition?
2146
1357
1150
462
