May 9, 2023 at 3:05 am
May 11, 2023 at 2:37 am
Muhammad Rizky Pratama Hakim
SubscriberHello Arba,
From your picture, the result actually shows the pressure, and regarding the error, the video did not show it and it should be calculated manually. The error is comparing the simulation to the analytical calculation. The analytical calculation can be done using the hydrostatic equation.
May 12, 2023 at 1:12 am
Arba Agos Aditya Pranoto
SubscriberThanks for the answer mr. rizky😁🙏
- Features of the check case
- Does anyone know what this is caused by? – Cyclone Separator Simulation (CFD)
- Hydrostatic pressure simulation failure on a simple structure like a large aquar
- Error Floating Point Exception
- Heat transfer radiation through glass
- Room with Air-Conditioning Vents
- real fundamental difference in true tension body and engineered tension
- Convergency in mass flow rate
- Function mess balance in fluid flow
- Viscous Models
5410
3381
2471
1310
1022
