June 29, 2020 at 1:57 pm
Emmanuel001
SubscriberHi I am working on thermal analysis of reluctance motor . I intend to use Maxwell and Ansys. But, I am a bit confused on the versions of Maxwell and Ansys I used. I am currently using Maxwell 16.0 and Ansys 14.5 but I am getting error messages ("plugging errors" and "couldn't attach geometry"). I want to use higher versions of EM suite and Work bench. So which combinations should I use? Thanks all as I await for a perfect reply. -
June 30, 2020 at 12:31 am
tsiriaks
Ansys EmployeeIt's always recommended to use latest version of any ANSYS applications (currently 2020 R1)
Note: You need to make sure you have matching version for Maxwell and ANSYS (e.g., Maxwell/AnsysEM 2020 R1 with ANSYS Workbenh 2020 R1, etc.)
June 30, 2020 at 6:12 am
Emmanuel001
SubscriberThank you for the recommendation. It has solved my challenge -
July 3, 2020 at 12:33 am
tsiriaks
Ansys EmployeeGood to hear ! Thanks for the update.
- Workbench error
- Workbench not opening
- License Error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
3612
2502
1729
1222
578
