September 27, 2017 at 11:19 am
nselvara
Ansys EmployeeHow can I compile and load a UDF when running Fluent via a journal file?
October 17, 2017 at 7:39 am
Arun
Ansys EmployeeThere are two commands needed. The first to compile the UDF: /define/user-defined/compiled-functions compile libudf yes sourcename.c "" And the second to load the library that was compiled in the previous step: /define/user-defined/compiled-funcitons load libudf Note that 'sourcename.c' is the name of your UDF file and the "" are two quotation marks in sequence (needed to terminate the string array input to Fluent).
October 26, 2022 at 11:40 pm
mashimaro_star
SubscriberIf I want to compile multiple c codes, can I write /define/user-defined/compiled-functions compile libudf yes sourcename1.c sourcename2.c sourcename3.c"" ? Or what should be the correct format?
Thank you.
May 29, 2023 at 8:34 pm
TONY ARHUR
Subscriberi am getting this error "
rotating_screws.c(2,10): fatal error: 'motion.h' file not found
#include "motion.h"
1 warning and 1 error generated.
scons: *** [rotating_screws.obj] Error 1
please i need help
5454
3419
2475
1310
1022
