November 20, 2018 at 4:31 am
Phihong
SubscriberPlease help!
Hi everybody, I am a beginner at ANSYS. I already learn a bit about compiling UDF in ANSYS Fluent. I am wondering that might I compile in other apps, such as: Steady-state thermal, Static Structural and so on.
What I mean is: If I want to compile UDF, I must use ANSYS Fluent? Is there any other way to compile in ANSYS?
Then if my model is in "Static Structural or Steady-state thermal", and I have UDF in a C-code, how can I compile?
Please kindly to answer me. Thank you.
November 20, 2018 at 4:35 am
Keyur Kanade
Ansys EmployeePlease check this
November 20, 2018 at 4:51 am
Phihong
SubscriberThank you very much for your quick reply Kkanade. However, the above video is for Compiling ANSYS Fluent with C-code.
What I mean is: If I want to compile C-code with other apps, such as "Static Structural or Steady-state thermal", then how can I do?
November 20, 2018 at 10:20 am
Ansys EmployeeA UDF is used in Fluent only. The equivalent for Mechanical is "code snippets" and they're written in APDL command language: you'll want to ask questions about those in the Structural section of the forum.
November 20, 2018 at 10:56 am
Phihong
SubscriberDear Rwoolhou,
Thank you a lot for your answer, I will ask this question in Structural Section.
2522
2064
1279
1094
456
