November 2, 2018 at 5:12 pm
jmt714
SubscriberHi!
I am trying to compile the following UDF:
#include "udf.h" int last_ts = -1; DEFINE_GRID_MOTION(mitral_movement,domain,dt,time,dtime) { Thread *tf = DT_THREAD(dt); /* zone */ face_t f; /* faces*/ Node *v; real NV_VEC(axis), NV_VEC(dx); real NV_VEC(origin); double displ[105] = {-2.31110880000000e-05, -5.78353680747664e-05, -5.87595468992113e-05, -6.46174026334990e-05, -0.000103825859674563, -0.000217079075525136, -0.000256401435192825, -0.000275866756577904, -0.000358596163999863, -0.000308366495539297, -0.000319002682794429, -0.000349618421760680, -0.000349129134802423, -0.000300145791513366, -0.000314688030776492, -0.000344275931036111, -0.000314687932121784, -0.000314656644654236, -0.000314656753976871, -0.000322590075194713, -0.000308334554732122, -0.000326125198519708, -0.000307366719488318, -0.000308929159594051, -0.000329482076917630, -0.000338576347580837, -0.000299061755676187, -0.000300230079537407, -0.000253449986499882, -0.000198312769317913, -0.000180340556903472, -0.000112397338561133, -8.40003618339527e-05, -7.77792472565544e-05, -7.88121189048852e-05, -0.000104891305927779, -0.000119703840000000, -0.000104687803423177, -5.93107999770712e-05, -2.91863885997525e-05, 1.21481359999986e-05, 7.89120094802929e-05, 0.000151316152702385, 0.000284436240311541, 0.000359121893179136, 0.000314656460656127, 0.000299841953976870, 0.000251261035685624, 0.000255425054236490, 0.000289177263771537, 0.000318807335756432, 0.000315266920243571, 0.000380260120398392, 0.000421821689890560, 0.000590536034702553, 0.000763826675008497, 0.000607407407999999, 0.000575424127331443, 0.000466356689754228, 0.000179550340995987, 4.74094579183375e-05, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 3.00247079537410e-05, 3.49618091102193e-05, 9.08748293603945e-06, 0, 0, 4.91856954448908e-05, 0.000100144131885768, 0.000161188712669342, 0.000235867164603402, 0.000330651455396601, 0.000412044074505546, 0.000294341911446777, 0.000247095542047674, 0.000125480123400247, 1.43715885997522e-05, -4.85880332094179e-05, -0.000104893294790583, -0.000159999839999999, -0.000138667891727386, -7.52536644170562e-05, -9.24489918555579e-05, -5.52571190150475e-05, -6.97790502339493e-05, -6.87452874203444e-05, -0.000101185005521489, 0.000796299778190831, 0, 0, 0, 0}; int n; int curr_ts; curr_ts = N_TIME; /* set deforming flag on adjacent cell zone */ SET_DEFORMING_THREAD_FLAG(THREAD_T0(tf)); /*NV_S(omega, =, 0.0); */ NV_D(axis, =, 1.0, 0.0, 0.0); NV_D(origin, =, 0.0, 0.0, 0.0); begin_f_loop(f,tf) { f_node_loop(f,tf,n) { v = F_NODE(f,tf,n); /*function that pickes up the node */ /* update node if x position is greater than 0.02 and that the current node has not been previously visited when looping through previous faces */ if (last_ts != curr_ts && NODE_POS_NEED_UPDATE (v)) { /* indicate that node position has been update so that it’s not updated more than once */ last_ts = curr_ts; NODE_POS_UPDATED(v); NV_V_VS(NODE_COORD(v),=, NODE_COORD(v),+, axis,*,displ[last_ts]); } } } end_f_loop(f,tf); }
And I get this error: LINK : fatal error LNK1104: cannot open file 'libudf.dll'.
I don't know if it is because of my udf function that is wrong coded, or because it lacks some compiler.
Thank you very much in advance! -
November 5, 2018 at 11:31 am
Ansys EmployeeWhat else did Fluent output when the UDF failed to compile? Was there anything about nmake? Have you got (and linked) a compiler on your computer?
November 5, 2018 at 12:24 pm
DrAmine
Ansys EmployeeTo add to rwoolhou message: check if you have already an UDF loaded into your case!
August 21, 2020 at 11:15 am
CFDGer
SubscriberI actually have the same question regarding a UDF for my specific heat cp(T).
I receive a similar error message:
LINK : fatal error LNK1104: cannot open file "kernel123-lib".
I don't receive the warning regarding the nmake.
I use FLUENT 2020R1 and the current Microsoft Visual Studio Community.
I have read something about some Environment Variables but I'm not sure what to do exactly.
Thanks
August 21, 2020 at 11:35 am
DrAmine
Ansys EmployeeCan you compile this one:
#include "udf.h"
DEFINE_ON_DEMAND(Hello)
Message0("nHello World!n");
August 21, 2020 at 12:06 pm
CFDGer
SubscriberThanks for your reply!
No, unfortunately this doesn't work aswell.
I already checked the Ansys Customer Portal and the case numbers
#2041677
and
#2061708
But I couldn't find any of the mentioned environment variables on my system.
What does this all mean now?
August 21, 2020 at 12:08 pm
DrAmine
Ansys EmployeeWhat about launching from the x64-86 VS command prompt as indicated in the solutions?
August 21, 2020 at 12:19 pm
CFDGer
SubscriberI don't know what to enter in that command prompt. I mean, which folder or file am I supposed to cd to? The FLUENT .exe?
August 21, 2020 at 12:21 pm
DrAmine
Ansys EmployeeCheck #2059458
August 21, 2020 at 1:02 pm
CFDGer
SubscriberThat works. I am now able to Build and Load the Compiled function, thanks!
But I can't open FLUENT this way all the time. Is this problem fixed now that I have done it this way once or do i always have to start FLUENT like this if I want to implement one or more UDFs?
August 21, 2020 at 1:29 pm
CFDGer
SubscriberWell, now that I tried that exact procedure a second time it says "nmake" can't be found.
August 21, 2020 at 2:40 pm
Ansys EmployeeIf you can update to R2 there's an inbuilt compiler: try that.
DrAmine
Ansys EmployeeYes the best solution.
August 24, 2020 at 8:16 pm
anshs
SubscriberHello Dr. Amine can you help me with a mass transfer udf problem :
My UDF for mass transfer is not running , the code stops at "Message("nn %f," , NV_MAG(C_VOF_G(cell,w)) );"
UDF:
DEFINE_MASS_TRANSFER(interface_transfer, cell, thread, from_index, from_species_index, to_index, to_species_index)
real m_lg;
Thread *w = THREAD_SUB_THREAD(thread, from_index);
Thread *o = THREAD_SUB_THREAD(thread, to_index);
m_lg = 0.0;
if ( ( C_VOF(cell,w)*C_VOF(cell,o) > 0.1 ) && (C_VOF(cell,w) + C_VOF(cell,o) >0.75) )
Message("nn %f," , C_YI(cell, w, 0));
Message("nn %f," , ( C_YI(cell, w, 0) - 0.00005 ));
m_lg = 0.4 * (NV_MAG(C_VOF_G(cell,w)))* ( C_YI(cell, w, 0) - 0.00005 ) ;
else m_lg = 0.0 ;
return (m_lg);
August 24, 2020 at 10:05 pm
Karthik R
AdministratorHello Please create a new post for each new discussion for better visibility on your issue.
If you add a message line to print M_lg, what you do get?
Thanks.
Karthik
August 25, 2020 at 6:42 am
CFDGer
SubscriberHi Amine and Rob, ok I will try R2. Thanks
August 25, 2020 at 6:45 am
DrAmine
Ansys EmployeeI will close this thread. please try R2 and report on your experience with the inbuilt Slang compiler ;)
2564
2080
1293
1106
459
