August 15, 2023 at 6:18 am
1829116
SubscriberHi,
I am trying to run a UDF for a dynamci mehs model on a HPC. I used these two lines to complie and load the udf:define/user-defined/compiled-functions compile "libudf" yes "udf.c" ""define/user-defined/compiled-functions load "udf.c"But I keep getting this error:
Auto-compilation skipped. Could not find "libudf" or input files for creating "libudf" libraryAny thoughts?
August 15, 2023 at 1:39 pm
Federico Alzamora Previtali
SubscriberHello,
is the udf.c file located in the working directory?
August 15, 2023 at 2:16 pm
August 15, 2023 at 4:24 pm
1829116
SubscriberI am using this command:
followup:/solve/patch () (part-steel_tube) temperature 30but getting this error:
Error: eval: unbound variable
Error Object: part-steel_tube
temperature 30 -
August 16, 2023 at 9:02 am
Ansys EmployeeTry running the command locally one step at a time. I think you need to move the brackets.
/solve/patch
()(part-steel_tube) () temperature 30 -
August 16, 2023 at 6:29 pm
August 17, 2023 at 1:43 pm
Ansys EmployeeThe output is going to be in Kelvin - all the Fluent UDFs use and monitors tend to return SI units.
7742
4502
2959
1449
1322
