Compiling UDFs Error
    • helen.durand
      Hello!
      There are several UDFs that compile properly on my local PC but fail to compile on a HPC system. The error message I receive includes the following:
    • helen.durand
      This is more of the error message. It is too long to include the whole message, so I included approximately the first third.
      Is your local machine Windows and the HPC LINUX? If so use
      dos2unix filename.c
      and try again.
    • helen.durand
      Hello Rob, thank you for the reply. Yes, you are correct about the local PC running on Windows and the HPC being Linux.
      I tired using the dos2unix command with all of the UDFs (entered using a Putty terminal) in my simulation and I am still receiving the same error message.
      Do you have another idea of what I could try?
      Thank you!
Viewing 3 reply threads
