Compiling UDFs in Linux
    • Albert Abraham
      I have written a UDF to run in parallel in C. It contains the global reduction macro PRF_GRSUM1(). This macro is not supported in Fluent while solving in parallel so I am trying to compile the code instead of interpreting it. I have tried to follow compilation instructions in the manuel however, the built-in compiler only works on Windows. I am not sure how to work around this issue to succesfully compile the code in Fluent on Linux. Below is the basic code I am using as a test for compiling.
      // A simple adjust to test if we can compile in Fluent on Linux
      #include "udf.h"
      DEFINE_ADJUST(comptest,d)
          Thread* t;
          cell_t c;
          begin_c_loop(c,t)
        C_UDSI(c,t,2) = 1;
            end_c_loop(c,t)
      As LINUX is a proper operating system there's a compiler included in the OS as standard. Just deselect the "use included compiler" and build as normal.
