September 16, 2018 at 7:08 pm
Krishna Prasath
SubscriberHi,
What is format to give complex port impedance for RFID antenna designs? Sometimes I get positive S11 value when change reactance number format, like if I include i in complex part or leaving i in complex part. Which one is correct?
Thanks
September 17, 2018 at 3:59 pm
slouie
Ansys EmployeeThe format for entering in a complex value under Port Impedance is:
resistance + 1i * reactance
September 18, 2018 at 7:54 am
Krishna Prasath
Hi Slouie,
I am using lumped port. I am giving real value for resistance and (1i*(imaginary value)) for reactance. Say 21 ohm for resistance and 1i*196 ohm for reactance. Still I am getting positive S11 over some frequencies.
Thanks
September 28, 2018 at 6:17 pm
asamaiyar
SubscriberPositive S11 in dB?
What is your convergence criteria?
September 29, 2018 at 3:57 am
Krishna Prasath
Positive S11 in dB?
Yes, Positive S11 in dB (over certain frequency range). Criteria is delta S <0.02.
October 5, 2018 at 9:52 am
dprestau
Ansys EmployeeWhen dealing wit complex impedance, you should also select " Generalized" for S parameters definition in HFSS Design settings. This definition will provide the expected S parameters.
January 15, 2019 at 3:45 pm
shanmei
SubscriberCan you explain more about the "generalized" option?
Do you know choose the port setting to be " renormalize all modes" to be 50 ohms? Thanks.
July 1, 2020 at 9:26 pm
jmnolan
SubscriberThe Zo value in the solution matrix does not match the lumped port complex impedance. I am using 2019 R3. Is something broken with it? When I use real values such as 50 or 80, the Zo value matches in the solution matrix, however with complex it is very different.
July 3, 2020 at 1:07 am
AndyJP
Subscriber"1i*" oh, I use it for years, but didn't know this.
Wait a minute! Do you mean, I can enter a complex permeability(mu) tensor in Transient solver? Or it will still tell me that "ferrites are not supported"?
- Maxwell, HFSS or Q3D?
- Error
2532
2066
1285
1104
459
