January 12, 2023 at 8:36 pm
kg
SubscriberIs there a way to obtain and export the complex radiation pattern of an antenna to a file?
January 18, 2023 at 9:57 am
Kasseyy Sk
SubscriberACIS entity check failed for part
Use Design Settings/Validation to relax ACIS entity checking or Modeler/Model Preparation/Heal to fix check https://testmyspeed.onl/ errors.
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1285
1096
459
