component problem in fluent with different bodies of the paratype topology
    • Emperor
      Hello to all,
      I'm trying to create a component with several walls, to use it as 6-dof. But in fluent the different walls are not grouped in the same component. I think it's because the elements don't belong to the same body of the shared topology and are not meshed with the same elements. Do you know how I can solve this?
      Body with shared topology :
      The walls are attached to different volumes so will split like you see. This is intentional so can't be changed. You'd need to merge the volumes (fluid-up , -down, -valve) to then allow the wall to be the same label.
    • Emperor
      thank you for your answer, this is the answer :)
