May 4, 2022 at 8:14 pm
k2.karimi740
SubscriberHi there,
I'm going to make a stress analysis simulation of a pipe made of a composite laminate as the middle layer and an isotropic material for two side layers, as you can see in attachments. a moment is exerted at two ends of this pipe as rotation of two ends, not as a moment load that I defined it as remote displacement. I tried to simulate it using APC pre and static structural, but I face this error:
An unknown error occurred during solution. Check the Solver Output on the Solution Information object for possible causes.
and the solution information is as followings:
May 4, 2022 at 8:15 pmk2.karimi740
Subscriber*** NOTE ***CP =14.047TIME= 14:37:49
Symmetric Deformable- deformable contact pair identified by real
constant set 11 and contact element type 11 has been set up.The
companion pair has real constant set ID 12.Both pairs should have
the same behavior.
ANSYS will keep the current pair and deactivate its companion pair,
resulting in asymmetric contact.
Linear contact is defined
Contact algorithm: Augmented Lagrange method
Contact detection at: Gauss integration point
Contact stiffness factor FKN10.000
The resulting initial contact stiffness0.10542E+15
Default penetration tolerance factor FTOLN0.10000
The resulting penetration tolerance0.74804E-03
Default opening contact stiffness OPSF will be used.
Default tangent stiffness factor FKT1.0000
Use constant contact stiffness
Default Max. friction stress TAUMAX0.10000E+21
Average contact surface length0.20141E-01
Average contact pair depth0.74804E-02
Default pinball region factor PINB0.25000
The resulting pinball region0.18701E-02
Initial penetration/gap is excluded.
Bonded contact (always) is defined.
No contact was detected for this contact pair.
*** NOTE ***CP =15.422TIME= 14:37:50
Predictor is ON by default for structural elements with rotational
degrees of freedom.Use the PRED,OFF command to turn the predictor
OFF if it adversely affects the convergence.
*** WARNING ***CP =20.172TIME= 14:38:03
An error has occurred writing to the file = 3 which may imply a full
disk.
The system I/O error = 28.Please refer to your system documentation
on I/O errors.
May 4, 2022 at 8:20 pmpeteroznewman
SubscriberYour disk is full.
May 4, 2022 at 8:48 pmk2.karimi740
SubscriberThank you very much;)))
Viewing 3 reply threads- The topic ‘composite-isothropic material simulation in static structural’ is closed to new replies.
Trending discussions- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
