November 2, 2023 at 4:34 pm
Noureldeen Radi
SubscriberHow Ansys calculates deformation in beams made out of isotropic materials
I used transformation section rule for solving for deflection analytically but the value is different around 22mm for Ansys apdl result and 52mm for analytical results
November 3, 2023 at 2:11 pm
Mike Rife
Ansys EmployeeHi Noureldeen
Before getting into materials, which beam theory did you assume in your hand calculations? Mechanical APDL uses Timoshenko beam theory for Beam188/189.
Mike
November 3, 2023 at 2:28 pm
Noureldeen Radi
SubscriberHello, my question was. Not clear
I used she'll 181 fo so how ansys calculates the deflection and stresses on my beam.. I have a 4 point force and 3 isotropic materials in 1 composite lay-up... Finally all modeling is made in areas..
How ansys calculates it analytically?
And should I do any boundary conditions or initializing any equations?
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- Material library
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- About Bilinear Isotropic Hardening Plastic Model !
8758
4658
3151
1678
1456
