TAGGED: air-water-flow, compressible-flow-air, mixing-tank
April 13, 2023 at 2:35 am
April 13, 2023 at 12:22 pm
Nikhil N
SubscriberHello,
Can you please post your doubt?
April 14, 2023 at 2:12 am
April 14, 2023 at 5:33 am
Nikhil N
SubscriberIt appears that the solution is diverging. Firstly, check the mesh quality, particularly the minimum orthogonal quality. Secondly, you can try reducing the time step size. A smaller time step allows for better accuracy in capturing the physics of the problem and can help stabilize the solution. It's recommended to keep the CFL number as close to 1 as possible, as this ensures stability and accuracy.
April 14, 2023 at 2:15 am
Shayne Ondray
Subscriber-
April 14, 2023 at 5:40 am
Nikhil N
Subscriber1: If the problem involves complex geometry or flow patterns that cannot be accurately captured in 2D, then a 3D model would be necessary to obtain accurate results. However, if the problem is relatively simple and the flow is primarily in one direction, then a 2D model may be sufficient.
In general, 3D models can provide more detailed and accurate results but are computationally more expensive compared to 2D models. Therefore, the choice between 2D and 3D modeling should be based on the specific requirements of the problem and the available computational resources.
2: That's correct. One phase would be water, and the other would be air. You may have to patch (initialize) the water in the domain. VOF model will track the distinct interface between the two phases.
April 14, 2023 at 5:58 am
Shayne Ondray
Subscriberthank you for the explaination Nikhil. My problem's requirement is to identify how much pressure I need to put into the tank to flush out the water. would you think 3D model will be benificial on this scenario?
thanks again -
April 14, 2023 at 6:44 am
Nikhil N
SubscriberBased on the specifics of the situation, I recommend utilizing a 3D approach. This is due to the fact that the diameter or width of the inlet/outlet pipe or duct varies from that of the container, which necessitates accounting for 3D effects.
April 14, 2023 at 6:48 am
Shayne Ondray
SubscriberThank you -
April 14, 2023 at 7:00 am
Nikhil N
SubscriberYou're welcome!
- The topic ‘Compressed Air to Flush out water on tank’ is closed to new replies.
- How do I get my hands on Ansys Rocky DEM
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Script Error
- Facing trouble regarding setting up boundary conditions for SOEC Modeling
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
- Errors with multi-connected bodies using AQWA
2042
897
599
591
454
© 2025 Copyright ANSYS, Inc. All rights reserved.
