Compressible and Incompressible flow modelling
    • Rachit Bundiwal
      Hii , i am modelling a multiphase VOF problem and in it i need to run air as compressible and water as incompressible in a pressure based solver . can anyone help me out how to do that ?.
    • SRP
      You need to air as a primary phase since it is compressible for better solution stability.
      Can you please explain in more detail what exactly problem you are facing while modeling?
      Thank you.
    • Rachit Bundiwal
      Hi thanks for reply , i am trying to simulate a swirl flow using K-e RNG , using velocity inlet as BC , for both the inlets . but the problem arises during the initialization , when primary inlet is selected it is not showing it . And showing absurd values . Any resons for that ?
      Forum Moderator
      You may need to rethink how you initialise the problem. Pictures will help us understand what you're up to.
Viewing 3 reply threads
