Compressible and incompressible
    • Karthik R
      Administrator
      Hello everyone, can someone tell me what is the difference between compressible and incompressible flows? Is it just to refer to gaseous and liquid flow?
    • prajput
      Hi, while fluids and gases have different compressibility, both can be assumed to be incompressible under certain circumstances. An incompressible flow is defined as a constant density flow, while a compressible flow is defined as a variable density flow.
    • Keyur Kanade
      Adding to response, in a fluid moving at a Mach number of a flow is lower than 0.3 the variations of density are small and the fluid can be assumed to be incompressible. If M>0.3 the fluid can be assumed to be compressible.
