COMPRESSION TEST
    • saurabhiitk
      Dear friends
      1) I want to simulate the compression test of  ABS specimen(its an honeycomb structure) in ANSYS.
      2) Should i use the tensile test data of standard ABS specimen(obtained experimentally)  to model the material for plasticity or
      3) Will I have to do compression test of a standard cube element of ABS and then use the data obtained to model the material for plasticity?
      please reply
    • Wenlong
      Hi sarabhiitk,
      It depends on whether your material has a different young's modulus, yield point and hardening modulus in compression and tension. If yes, you do need to obtain a separate set of experiment data in compression.
      However, you may use the tensile data as a placeholder to set up your model first. If after your research you do believe a compressive data is needed, you can simply replace the material properties in the model.
      Wenlong
    • saurabhiitk
      Hello Wenlong
      Thanks for your reply.
      what should be the dimensions and shape of the model to be tested under compression?
      Regards
      SAURABH
    • Wenlong
      Hi Saurabh,
      That I am not familiar with but I am sure there are some standards in ASTM: https://www.admet.com/testing-applications/testing-standards/astm-e9-metal-compression-testing/
      Or else you can find it in the literature.
      Wenlong
Viewing 3 reply threads
