March 9, 2022 at 3:19 pm
ZiadHatab
SubscriberHello!
I want to know. Is it possible to compute derivatives in Q2D in a similar way as done in HFSS? To be clear I'm not talking about sensitivity analysis in Optometric (I'm aware that Optimetric is available in Q2D). I'm talking about analytical derivatives as discussed in the reference paper I found in HFSS help file [1]. So, in HFSS there is an option to enable derivative computation in the analysis setup, but I don't see this option in Q2D? Is it because it is not possible in Q2D?
If derivative computation, like in HFSS, is not possible in Q2D, is there other ways to compute derivatives in Q2D? (excluding Optimetric)
Thanks
Ziad
[1] L. Vardapetyan, J. Manges, Z. Cendes, "Sensitivity Analysis of S-parameters Including Port Variations Using the Transfinite Element Method", 2008 IEEE International Microwave Symposium, Atlanta, Georgia, June 2008.
March 14, 2022 at 4:40 pmDan Dvorscak
Ansys EmployeeHello Ziad. Unfortunately the 2D Extractor does not compute analytic derivates the way HFSS does. I'm not sure of the exact limits for this. But in the paper you reference on the HFSS method computes the derivatives in the s-matrix. The 2D Extractor natively computes RGLC matrices per unit length, not s-matrices, so that may be a part of it. But again, this functionality does not exist. The only derivate info we have for the 2D Extractor is what is available through Optimetrics. If that is not sufficient, you will probably have to work with full 3D designs in HFSS.
- Maxwell, HFSS or Q3D?
- Error
2656
2120
1349
1118
461
