June 25, 2020 at 10:54 am
mekafime
SubscriberHello everybody,
Please could you help me with a problem?, when I reduce the mesh size less than 2mm in a model the computer freezes, I already tried in two computers and the same happens I have research license, I even generated a sphere for only reduce the meshing in the critical area and leave the rest of the model in a larger size (with which it simulates correctly). What can I do to solve it, since there are other users that use smaller mesh size and their computer does not freeze during the simulation?
June 25, 2020 at 12:49 pm
Ansys EmployeeI assume you mean the minimum cell size. Check the smaller size isn't trying to capture very small edges or faces in the model: that can cause the cell count to increase significantly higher than you're expecting.
June 25, 2020 at 5:03 pm
June 26, 2020 at 6:11 am
Keyur Kanade
Ansys EmployeeWhat is meshing method?
Please try patch dependent tetra.
Keyur
June 26, 2020 at 3:14 pm
June 29, 2020 at 4:26 am
Keyur Kanade
Ansys EmployeeFew things to consider.
Student license has limits.
Structural Physics: 32K nodes/elements
Fluid physics: 512K cells/nodes
Please check your RAM. Usually 1GB can produce approx 2-3M cells depending on geometry and size functions used.
Please try to reduce your problem by reducing geometry.
Also check sizing controls.
Keyur
- check element type
- Meshing Error
- How to resolve Mesh Failure
- Error in meshing
3930
2649
1869
1272
610
