concrete and steel bond, pullout model
    • awawdeh
      I am modeling the bond between concrete and steel using mechanical APDL 19.2, I first modeled the steel using link180 and the concrete solid65. For the bond behavior the combin39 was used. I got good results after that when compared with the experimental results. I then tried to perform a transient analysis and see if the effect of loading rate on the bond behavior but I only got the same results as the static analysis. If I used the contact element  would I be able to study the effect of loading rate.
      thanks
Viewing 0 reply threads
