May 1, 2023 at 12:45 am
Korrenn Broaddus
SubscriberSo i'm trying to model concrete to failure in Explicit Dynamics. I'm currently using concrete-L just to get the hang of things, but I was wondering how to change the material properties to the ones I want for my actual analysis. I've attached an image of the engineering data below for the default Concrete-L in explicit materials.
The material properties I need to be able to change for my analysis are:
- Young's Modulus,
- Compressive strength
- Tensile strength
Could someone help me see where these properties are stored in here, and how to change them.
If I add the linear elastic properties, will it overide the drucker-prager behavior, or will that still work?
Thank you so much.
May 3, 2023 at 10:58 am
Ashish Khemka
Ansys EmployeeHi,
Please see if the following link is of help to you:
11.8. Brittle/Granular (ansys.com)
How to access the ANSYS Online Help
Ashish Khemka
May 3, 2023 at 4:11 pm
Korrenn Broaddus
SubscriberThank you Ashish
- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
5290
3311
2469
