August 24, 2023 at 7:02 am
Sree Ranjini
SubscriberHello,
What are the possible feasible values for conductor separation and copper depth for round winding configuration in MOTORCAD? Kindly mention the lower and upper ranges.
Thanks in advance.
August 25, 2023 at 3:42 pm
HDLI
Ansys EmployeeHello Sree,
I would like to use default values for both. Conductor separation could be determined by manufacture process and insuation coating thickness. I suggest to enter 100% for copper depth of normal motor design. The slot fill factor of bare wire/slot area would not be larger than 45%, but it is also based on motor manufacture and your design. Please check them.
HDLI
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7626
4456
2955
1427
1322
