December 4, 2022 at 10:30 pm
Patrik
SubscriberHello each other
I would like to write configuration parameter values to the database from a previous calculation.
See APDL Command
fini
/config, noeldb,0
/solu
in the solve.out file I get the following message.*** NOTE *** CP = 1.328 TIME= 20:36:18
The /CONFIG,NOELDB command is not valid in a Distributed ANSYS
solution. Command is ignored.My question is how do I make it so that the /CONFIG,NOELDB command is not ignored?
The second question is what does the CP = 1.328 mean?I am using ANSYS WORKBENCH 2022 R1 ( student version )
December 5, 2022 at 7:50 am
Erik Kostson
Ansys EmployeeHi
As the message says:
solutionSo as it is not valid with a distributed analysis do not use distributed perhaps. It is a note though. CP is related to the computational time (CPU time)
All the bestErik
December 5, 2022 at 1:31 pm
bhagwantP
Ansys EmployeeHello Patrik,
Just an additional reference:
where it says “Distributed-memory parallel DMP solutions use the default FSPLIT value and force NOELDB = 1 for all results files. You cannot change the FSPLIT and NOELDB options for a DMP solution.”
Meaning :
Thanks
2098
1323
1108
461
